scott.livesey
Dealer - Purveyor
i have been experimenting with different speed and coolant combinations while grinding. I am going to start recording data and see which combinations work the best. the key is Standard Work, what task are we going to do. if i say blaze belts last twice as long as gator belts, have i really given any real information? now when i say using a blaze belt at ?speed and using ?? for coolant, i made 20 cuts before the belt was used up. using a gator belt at the same speed and coolant, I made 10 cuts before the belt was used up. this is info that is relevant and repeatable.
So, would "make a 10 degree bevel, 2" wide, and 0.04"(about 1mm) deep" a realistic task?
