22h2,
I have used the spinning tool, I think the SS I was using was 303SS, the main problem I had was getting the right amount of pin left to spin. Is that similar to your problem? There is the old way of making domed pins, but you have to be a perfectionist type of freak (like I'm accused of being)! And that's by using files, I've actually used an emory board like used on lady's fake finger nails, obviously it won't take off much material at a time but that's a good thing, if you do leave too much material sticking up, the emory board can shorten it too. Do keep in mind that SS is rough on them, so you'll need about 3 to 5 depending on how many pins you'll have. I'm not sure how well they will work on the SS you're using. The other option which I think might be better, is a "points file". If you can remember when a tune up for a car included "points and Plugs", it's a pretty small file, and works great. I got mine from Sears. The biggest advantage of the emory board is that it is flexible, that helps a little with the curvature of the dome. Hope this helps, Rex
BTW, using the combination of the 2 does work well too, using the files to get it close and the spinning tool to finish the domed part of the pin.
One more thing, in case y'all didn't know this, Sears Craftsman warranty DOES APPLY to files, if you wear it out, take it back and they give you a NEW ONE!!! I asked them when I learned this, and that's where I get most of my files. Even the little mini/micro/ what do you call them, Swiss maybe? Oh yea, needle files, I broke one, took it back and the guy there pulled a brand new one from a set, just like the one I bought!
