Rotary Platen and Its uses...
Battle Creek Knives
I asked about a radius platen but was thinking rotary platen, which is fine because I was going to do a radius platen a while back but have to little time atm..
What is the purpose of a Rotary Platen Attachment as seen on beaumont ??(wont let me direct link it)...
To me it seems like you can get the same finish with a slack belt and more tension??
has anyone used/have one?? what kind of finish can you achieve with this that you cant without it??
thanks
thanks
I think the purpose is less about finish (you get that with different belts) and more about geometry. I've seen a lot of guys use it for grinding convex blades, or even for shaping handles.
I'm sure you are right that you can achieve similar results with a slack belt, but I think this reduces the learning curve quite a bit, and gives you a bit more consistency.
I don't know for sure, but I think it may help eliminate the bumping in some belts. i would like to have one for handle work.
I have a Hardcore Products Cushioned Platen.http://www.hardcore-products.com/section.php?xSec=11 Second unit down.
This sweet attachment has a serpentine belt that you can adjust the tension on for grinding and sharpening knives. It does help with the Bump Bump when using those belts, The Origin of this was a idea from Ken Onion and developed with Rob Frink of the KMG fame.
At the time I worked with Rob on a prototype of a unit for the Hardcore/Burr King grinders. I am not a machinist and we were unable to get it to work smoothly so I sent it back to Rob.
A few years later Randy of Hardcore worked with Ken Onion and was successful in making the Cushioned Platen for the Hardcore.
I don't know if this will work on a Burr King? As mentioned this unit is more about shaping than what kind of finish you can get. I get the same finish weather Grinding flat or con vexing.
The primary things I use this con vexing Platen for are,
after heat treat I take my Flat ground culinary Knives and convex the blades with this unit.
I get a nice even tension from the adjustable belt and it allows me to use any weight belt and get the same consistent Convex grind on the blades,
Work's great for handle sculpting and I get great results using it to sharpen my customers knives.
I generally run it at 25% power on my HC grinder with a 1.5HP Variable Balbor motor.. This speed with sharp new belts does a excellent job in allowing me to also control the amount of Convexing and flats I have in the particular knife model I am making at the time.
It seems that people ether love them or hate them!
I love mine! :7:
Laurence
www.rhinoknives.com/
I have the KMG Rotary Platen. I use it on every knife I make. It's the cat's Meow for working handles. It can be rotated to three belt length positions, and at any angle. It is pretty much a reinforced slack belt, but it sure works well for me.
If I am making a large chopper and want a convex edge, I will use it on those also.
Kind of pricey, but worth it IMO.
Robert
Does the kmg rotary platen have a work rest?? I've only seen them free hand... they are really pricey, but I think it would really help my style as convex is right up my alley..
so I'd assume one would use a flat platen, or wheel to profile and bevel their knife.. then use this on the final stages of the profile geometry ???
Yes Robert.. Keep in mind that going from flat to convex is a change & Going from Concave to Convex is a really big one!
I'm not saying it can't be done! I've done it a few times.
I just want to caution you to think it out completely before you start grinding away or you will end up with a screwed up piece of scrap.
Cheers!
Laurence
