Vombrown
Banned
I'm about to start building my new larger forge. The inside diameter will be 8" diameter and about 24" long. I'm wondering how long the burner would need to be. Also wondering wether 3" or 2" square tubing for the burner body. Last thing is this, on all the designs I have seen, they remove a circle of steel in the central locations where the pipe is welded. Then weld in a piece inside the manifold drilled with holes. I'm wondering why you couldn't mark the pipe location, possibly dimple the area and drill it. Then weld the pipe on. It seems counter productive to cut out the piece and then weld a piece of steel in the exact same spot. I understand that this piece is only acting as a diffuser to help mix the gas and oxygen entering the manifold. Why does it matter that it is 1/8" lower than flush? I understand that some people weld in a thicker piece in this location than the manifold thickness. I have the materials here to build six or seven of them and I'm feeling like I might just do that. Test this littlle thing and possibly a few more engineering ideas I have.
Please keep in mind, I'm not looking for links to other pages and builds. I have done the homework on this.
