C Craft
What I am speaking of goes, by different names depending on the area on the map it comes from!
This is a Spanish Navaja
Sorry about large pic but it was like this when I pulled it from the net!
This one is a German okapi.
There are others that are pretty much alike! So here is my questions to anyone that has ever built one!
What would you use to make the spring back! It has to be thin quality steel, that is capable of being annealed and heated to shape and then the steel would have to be hardened to obtain the spring action!!
Next question is the lock indent on the spring back! Is that cut from the spring and folded down or is it something is added from a separate piece of steel riveted to spring back!
This one has the lock punched out of the spring material!!
However I have also seen one that the lock pawl was made from a piece that resembled a U. The spring had been drilled and the two pegs the formed the top of the U had been riveted on the top of the spring. It may have also been soldered as well!!
Unless I am missing something there has to be little clearance when the blade is closed into the blade slot, between the blades edge and the pin that holds the saddle of the spring!!
I have a client that wants one and I am looking at slowing down the learning curve on actually building one! :what!: :biggrin: Anyone got any advice on this subject??? I have been looking for information, on the construction of one, but so far without much results!!
