Quench Plates
F
Fitz
Guest
Is 3/16'' aluminum thick enough for a set of quench plates(for cpm 154) or does it need to be closer to .250.
Andy
Andy,
I purchased 1" thick plates - reading elsewhere I remember someone using 1/2" plates.
Stand by for a few of the more experienced guys to chime in.
BC
3/16" is not thick enough. You need more mass to pull the heat away fast. Go at least 1/2" and 1" is better.
I'm with Rusty,I use 1-1/2" X 12 X 12 Aluminum. Blade at room temp in about 90 seconds.:D
Stan
Excuse me for butting in. Where did you guys buy these large plates? Does it matter what alloy of aluminum, i.e. 5052, 6061, etc?
The alloy isn't all that important. Aluminum conducts heat at pretty much the same rate across them all. Copper is actually better but it's insanely expensive right now.
Thanks Tracy & David. One more question if you don't mind. Can you bolt two plates together to get the 1" or 1.5"? For example, 2 pieces that are .5" each or 2 pieces that are .75" each. I haven't calculated it out but I am guessing that might lower the price a bit?
That sounds like its worth a try to me. Apply some electrical heat sink compound between the plates for best results. I find thinner scraps much more easy to come by.
I'd say yes if they match up well. The thermal conducting paste will help but if the plates are flat, you should be OK.
