Clarity is the major issue with this photo.
The point and butt of the knife are out of focus. Only the center is sharp.
I was experimenting with my 50mm lens and exploring the depth of field variations with it. If shot at f11, as Buddy says, the entire knife would be in focus and it would have more "pop"…
So the rating game goes
Composition-2 (one or more minor flaws) The knife is off center horizontally. Not far enough off center to be deliberate and a design element, but off just enough to look… well… wrong.
Lighting-2 (one or more minor flaws) The lighting is flat, the handle is dark, the pins don't shine and butt end of the handle disappears into darkness.
Color-2 (one or more minor flaws) The knife shows up against the background. That's about it. A neutral background is usually a safe bet. But the subject doesn't jump out at you, it sort of blends in. As if it was in a fog.
Clarity-2 (one or more minor flaws) As I said above, the ends of the knife are out of focus. The blade is dark, not to mention finger smudged.
The flat lighting also contributes to the lack of "pop" that makes you want to reach out and grab it.
Creativity-3 (no significant flaws) It is a pretty much standard knife on a white background shot. With the addition of the plexi base and card stock back.
The same set was used for the black plexi shot, lightbox, with white plexi and background.
