I just got the plans in the mail today and read through the material.
I have a couple of questions.
Tracking block brackets:
It says to use a 3"x1"x1/8" piece of bar stock and bend it to 90*
I have 1.5" x 1.5" x 1/8" angle iron on hand, can I use that or is there a reason that you have to bend it yourself that I haven't figured out yet?
Flat platen attachment:
It says - 1.75" x 1.75" x 1/8" angle iron (2"x2" is ok also)
As I stated above, I have 1.5" x 1.5" x 1/8" angle iron on hand, can I use that? Will it give enough room for adjustment of the angle of the platen?
Hope this makes sense. I know I will probably have more questions as the build progresses, so bear with me.
Thanks!
Thanks!
