1. Grind out shape and bevels on grinder
Yep.....some notes:
-leave your edge 3/32"+ thick..... the thicker you leave things, the less likely things will warp in the heat treat.
2. Hand sand flats and bevels to 220 or 320g
-I don't hand sand before heat treat, but you can. Got to at least 120 grit finish....any scratches larger then 120 grit CAN create stress risers.... places were cracks can happen.
3. Heat treat & temper (scrub carbon junk off between temper cycles)
Yep....this is always the area where the most trial and error comes in....everybody uses slightly different setups/methodologies.....and there are always variables present to deal with.
4. Clean up bevels and flats on grinder with 320g +
Post heat treat grinding is what most call "Finish grinding". In this step you want to do as much as possible on the grinder, as the heat treated steel is very difficult to hand sand (compared to pre-heat treat). I start with a fresh heavy grit (50) belt, and leave only enough for me to work through the rest of the grits I intend to use....it's always a bit of a guessing game, but it's get easier with time/repetition. That being said, you have to do it according to your current skill and comfort level. Generally I will go to 400 or 600 on the grinder, making the knife as close to finish as I can get it, in order the minimize having to remove material by hand.
5. Hand sand flats to 600g (leave high grit horizontal grind marks in bevel?)
You can do that, or finish everything out evenly.....some makers create a nice look by having different levels of finish on different part of a blade.....again, your skill and comfort level will dictate things.
Yep.... lots of things involved there.....but it gets more comfortable with each one.
