Don Robinson
Don't do it again.Don,
OK, same as fixed knife only stubby on a folder. This area will not be in direct contact with the soldering..... still a discoloration problem you think?
L
L
Practice makes perfect.Man this place is dead huh....
oh well.... got to grinding the blade this evening. For the first go I’m not to disguraged but I do wish I had a more consistent grind line, especially since I am useing a jig. Either way happy I didn’t destroythe blade.
I also epoxy glued the scales to the linersso that is setting up overnight.
View attachment 66100View attachment 66101
That is a good grind line. Hand sanding will make that line perfect.
It looks like you are getting some wiggle or uneven pressure as you make your grinding pass. It is very minor at any rate.
I think you are doing great with this build.
I think you have done a very fine job. In my opinion all it needs is to break the corners slightly and a good hand sanding to get rid of any scratches.
