Chris Railey
Are we talking Tide or Dawn? Or does it matter?detergent
I thought I was the only one...Dawn doesn't get off my hands acetone and a rag does.
...and should put you in a good mood!Joy is well known for anti static.
Yes.Based on the raving reviews for a glass platen, I'm tempted to add it to my grinder.
But - When my platen gets "groovy" I've been simply removing it and milling off .005-.010" - and, bingo, I'm flat again.
So, the question I have for you glass guys - will I see much improvement by using glass vs keeping the metal surface flat?
That explains why I do not get it here. 200% humidity...even in “winter”.Static sparks are usually only a problem when it’s very low humidity.
Do you use a hardened steel platen?I ground on a steel platen for years without issue, but switched to glass on Tracy's recommendation. About a month later I switched back to steel. For the way I grind, it was not a good experiment. This is my answer to static shock. I have one on each grinder.
YesDo you use a hardened steel platen?
I imagine that would last a good long while as well as not constantly wearing like mild.
