Rob Nelson
So the handsome rascal in my avatar was in desperate need of his own necker.
OAL: 5" or so.
Blade: 2.5" or so.
Steel: Unknown Stainless (whatever Farber uses in their cheapest chef knife) w/ factory grind. 120 grit clean up of flats, handle polished to 400 grit, you can see a faint line just above wrap.)
Black Widow Paracord handle (minus strands)
Franken-plastic sheath (internal pack frame material from cheap chinese pack, followed instructions for Kydex ... 7 minutes and no change, nanosecond later it curled up like a lasagna noodle. pressed using waxpaper, kitchen towel and a heavy book. Cleaned up with dremel, drilled, and used old dog tag chain.)
OAL: 5" or so.
Blade: 2.5" or so.
