Chris Railey
OK so I finally got to run my new to me HT oven (Evenheat KH418). I was tempering some blades and as the oven started to run its cycle my lights began to flicker. I work out of a garage shop so I checked inside too and the lights in there were flickering too. Not horribly, think more of a candle burning rather than the lights going on and off. Counting ramp time I ran it about 2 hours and 15 minutes, light flickered the whole time. The oven ran its cycle fine and appeared to operate normally so I have no reason to suspect there is a problem there. Nothing caught fire but I KNOW once my wife catches on she will freak out until I turn the oven off. My simple solution is to run it off of a generator. I have been eyeballing a small inverter generator for some time now to use in camping and stuff any way. My question is this, The site claims the oven runs on 120v 1560 watts at 13 amps. The generator has 1600 running watts. If I run nothing else should that generator be sufficient to run my oven for a few hours? I really want to buy the smaller generator because it will be easier to take camping and fishing.
