I decided to try to make some linen micarta scales for some folders I'm attempting. I haven't done this before so I watched a bunch of videos and it seems pretty straight forward. I decided to do it with a twist though and am not sure if it will work or not. I cut off a piece of stainless scrub pad and unraveled it.
Then I cut it into pieces.
I should be able to make scales for 4 folders if this works out.
The main ingredients with a wax paper covered board that I will lay them out on.
All layered up.
I clamped it up between my (USA Knifemaker :biggrin quench plates (covered in wax paper) and used a caliper to measure the 4 corners so it should be pretty flat and consistent when it's done. It will sit outside till the stink is off of it.
Instead of mixing the stainless in with the resin I sprinkled it between the 2nd and 3rd last layers of linen. If it doesn't look good it will go to the inside and I can still use the material (hopefully).
edited to add a pic of the knife so far....
All layered up.
