Flatblackcapo, since 1095 is one of the trickier steels to beat that nose with, you will need a good fast quenchant for full hardening and many that I know of which are sold in smaller, inexpensive quantities tend to be medium speed. Steel chemistry is the key component in hardenability, cross sectional thickness affects heat extraction, a function of mere thermal mass. We can banter back and forth all day on the topic but pearlite won’t give a flip about our beliefs, it will just form regardless when the heat extraction cannot exceed the steels chemistry limitations. And then if you are too fast for that same chemistry you will have issues in the opposite direction. When viewing the image of your blade, I would ask if it is critical that you harden the spine area as well? Under ideal circumstances Parks #50 could harden all the way to the spine, but most slower oils will at least get you half way up that blade, if full hardness is obtained at least ½” from the edge you should be good with full martensitic structure where it counts. So how thorough you want it to be is your call.
One option if you want the blade done optimally in a real quenchant is to see if there is somebody who is already set up with the proper medium and see if you could use their facilities or have them do it. This is one of the things that I always admired about the stock removal guys, compared to us bladesmiths, if they didn’t have the proper setup to heat treat something they didn’t let pride get it in the way of making the best blade they could and would simply send it to somebody who did have the best tools. Of course there is also something to be said for having knowledge and overseeing that the heat treat is done correctly even with the proper tools. Since the real main advantage of actual quenching oils is reliable, predictable and consistent results over the long haul, your momentary need for it sort of negates that, so as has been pointed out, canola at 130F may be best in your situation if you can’t make a visit to somebody who has the oil for the job.
