LlamaHerder
Hello Dogs - asking for some advice his evening.
I've had requests for two kitchen knives. Sweet! Not sure I can pull it off...
Everything I've made so far has used 1084. I harden my blades in a paint can forge, and its worked well from all the feedback I've received. But I can only find 1084/1080 in minimum .125" thickness, which seems thick for a kitchen blade. Sanding that down on a granite tile to something slimmer seems like no fun at all.
Can I successfully harden a steel such as 15n20, which is easily found in .095" thickness, in my cute little homemade forge? Does someone sell 1084 or 1080 in a smaller thickness and I can't find it? Or should I put off the kitchen knife requests while I badger the boss lady into approving a heat treat oven purchase? (Obviously the best option, but you know how management can be.)
That is in advance for setting me straight.
