Dan Youngs
Active Member
Hi I am new, have not made my first knife yet. I heat my shop with a wood stove and have no forge or HT oven. I read the about annealing a file in a forge or charcoal fire in the forum. So while a had a nice wood fire going last week end I set a 12" file in the coals and continued to add wood as I cleaned my shop and was thinking about how to start a knife project. I let the fire go out and 3 days later dug around the ashes and found the file. I can know cut it with a file. It has a slight bend to it. I tried the hammer it straight on a flat block of steel. It does not straighten easily.
Do I need it hot again to straighten? It only has about a 1/16 of and inch bend. In other words when it is flat on the table there is a about a 1/16 gap under it with the curve up.
I plan to make a about a 6" knife so maybe after I cut it, it will be straight enough?
I have a 2x42 belt grinder and a 4" angle grinder.... do you think it is ready to try shaping?
I look forward to you comments and suggestions.
Dan
Dan
