Nylund knives
Hi,
I have a folder that I need to clean up the pivot hole in after HT.
I ordered a adjustable barrel lap from usaknifemaker supply, but don't think I will recieve it in time so I have made my own needle eye lap from brass.
http://usaknifemaker.com/drills-tap...ink-bores-c-98-32/120-135-needle-eye-lap.html
Should the lap be exactly the size I want the hole to be or sligthly larger or maybe smaller. The laps have some flex to them...
What rpm should I use and should the blades be clamped down or keept loose?
I tried it with about 400 rpm in mild steel but wasn't int too impressed with the finish. I used fine valvegrinding compound.
Best regards
Jakob
Best regards
Jakob
