Hidden Tang WIP
This project is finished. I learned a lot doing it, not just construction, but also etiquette (thank you @J. Doyle). I ended up using Gene's idea of plugging the tang hole with brass rod and drilling through it for a smaller pin- it worked great. I have a lot more respect for those who make hidden tangs. Keeping everything straight, symmetrical and square was a challenge. Thanks to all for the input.
The steel is 1084, the spacers are copper and blued steel. The handle is Koa from Gene.
View attachment 70765View attachment 70766
Looks great! Well done.
Did you done the pins on this knife?
They’re peened. I started out leaving them slightly proud of the handle to try to dome them, but it didn’t quite work out that way.
Great job, Heikki. There is a very good tutorial on raised pins on you tube by Nick wheeler. Check it out. Very informative.
