samuraistuart
I recently acquired a stick of CruForge V, and I have a couple of questions I'm hoping you can help me with. I'm stock removal only, so no forging is done. Steel comes annealed and is quite soft and machinable. There is information online (not a whole lot) about the heat treat for this particular steel, so I have an idea of what I'm going to do, but I need some advice on normalizing/grain refining. I suppose I should add that I am using a homemade forge, I'm not able to be exact, but I like to think I can get close.
Carbon - 1.05% Chromium - .50% Vanadium - .75% Manganese - .75%
How high of a temperature should that first normalizing step be, and for how long? I was thinking that 1550 would be sufficient, with a hold of about 5-10 minutes. However, after a brief exchange with a fellow knifemaker, he suggested to treat it like you would Adlo's super spherodized 52100 (requiring an initial heat of 1650F for 5-10 minutes, up to 30minutes?)
After normalizing is done, and I'm about to austenitize at 1500, should I hold it at 1500 for 10 minutes as well, or can I quench once it's up to temp?
Thank you so much.
Stuart Davenport
Thank you so much.
Stuart Davenport
