Glass platen?
I'm getting a piece of fireplace glass to make a glass platen add-on. But, I hate getting shocked - something that's happening now even with a metal platen. I read a number of earlier KD postings on this subject and decided to give this stuff a try, instead of a wire harness. I'll just spray it on the back of the belts. It seems kinda expensive, so I'm curious to see what the "spritz-per-belt" cost works out to be. Perhaps there is some kind of home brew that would work just as well.
I was getting shocked on a grinder with no platen at all. Just a slack belt. I was sanding leather, too. Not even metal!
Tropical anti-static spray sounds like a good idea, but you're in Montana. Not very tropical there... You think it'll still work? :)
We use glass (on platens) on every grinder in the shop.
Borosilicate or fireplace glass has multiple brand names. Fireplace glass handles heat expansion better than “regular” glass. Proprietary versions are used in cooking glass pans, cups, etc. It is often called ceram, ceramic glass, pyro ceram, etc.
advantages: grinds significantly cooler due to lower friction, easy to install and replace, wears longer than hardened steel platens.
Disadvantages: it will generate static electricity in low humidity, it can crack or might even come loose if improperly installed.
The cost of the glass is slightly more than a hardened steel platen but it last longer. Glass will wear as does steel and will need to be replaced.
If you flat grind you need a dead flat platen or you will struggle to get an even grind line. I can not emphasize this enough. Make sure you platen is dead flat and does not have grooves or low spots.
We use and recommend JBWeld to install due to it’s higher heat rating. I keep a can of laundry anti-static spray by the grinders to knock down any static shocks if the humidity is low. I spray all around the belt and machine but this just doesn’t happen that often.
Regular and safety glass will crack from heat generated by grinding. I know this because I’ve tried both in the past. I can’t recommend this enough as a grinder mod.
Will you be getting some more glass platens on your site? I would buy one if you get some more.
Reminds me I need to check mine for flatness soon. May need to replace it.
I just mounted a granite platen on my 1x42 sharpening grinder. Just letting the epoxy set up so I.can try it
