ACLakey
I found an old Delta 1x30 belt grinder that I forgot I had, the frame was broken and the table was missing. I decided to make a Frankensharpener so I mounted it to a wood base, made a stainless steel guide rod and attached my Lansky clamp. I purchased a few good belts and a leather stropping belt...wow this thing can sharpen a knife.
![12573119_10205667123661360_3081758768523345267_n_zpsa4h27sil.jpg 12573119_10205667123661360_3081758768523345267_n_zpsa4h27sil.jpg](https://knifedogs.com/data/attachments/39/39533-4b14a11e836bc7e661c2ca29ae2a5e19.jpg)
![12573748_10205667122581333_8051638928813033394_n_zpscjup8jzz.jpg 12573748_10205667122581333_8051638928813033394_n_zpscjup8jzz.jpg](https://knifedogs.com/data/attachments/39/39534-6a34a3a98a90d5b9ce6551b989185189.jpg)
Like most 1x30 grinders, this thing is fast and requires a delicate touch...especially with the finer grit belts. It does build quite a static charge and shocks the crap out of me from time to time...any thoughts on grounding it? I also found the idler wheel creates a pitch to the belt so when using the slack portion of the belt and drawing the blade across it can eat the tips off. To cure this I sharpen on the platen and strop on the slack portion. Please post any thoughts or recommendations. At some point I will tear this thing apart and install the components without the frame and find a smaller drive wheel to slow the belt speed down.
