flatblackcapo
Hi there folks. I am going to be using some W2 that was forged down from round stock for a project. I am making a modified Kwaiken design with a hamon for a customer that is well aware of my lack of experience with W2 and hamons but he is a brave soul and is willing to give me a shot. If any of you would be generous enough to share your time and knowledge with me to aid me in making the best cutting tool I can it would be greatly appreciated.Here is what I am working with.
Steel - forged W2 .250
HT method - Evenheat oven with Rampmaster control
Quenchant - I need some recommendations here. I would like to use oil. A quench oil that I could get from Maxim would be ideal for me.Also, a quenchant temp recommendation would be great.
For achieving the hamon I will use furnace cement.
The hamon is secondary to a good cutting tool. If I get a good hamon , that would be great but getting the best cutting tool that I can make is way more important to me.
A little about the knife . It will be a full tang design with a chisel grind , convex tip and zero edge.The thickness at quench time will be close to 3/16"
Mr. Cashen , any input from you would be very much appreciated. I did go to your page on W2. I still had questions. Is there any soak time recommend ? what would you for recommended oil quenchant. What is a good quenchant temp? What would be a good starting temp for temper? When walking the hardness down are 25* F steps OK or would smaller steps be recommended?
