Forge Lining Question ??
Three Sisters Forge
Forum Owner-Moderator
Any Rx on cement to use. Just refreshing my info.
I use Satenite or Mizzou. The Mizzou is thicker and crunchy, but seems to hold up very well. It is listed as a refractory "castable" lining, but I use it to line insalwool.
Any suggestions ?
I did several layers of satanite to secure the kaowool lining. Then I used the Mizzou to lay a more durable and flux resistant floor. I've got a page on my website where I documented the lining process I went through for my forge (in the Shop Tour page) if you're interested.
You can do a forge entirely out of mizzou, but I think it would be much heavier (though durable), and also have a lot more thermal mass to heat up. So you may see longer heating times needed. The satanite at about 1/4" thick heats up quickly and radiates the heat back pretty well.
--nathan
I prefer Kast-0-Lite 3000. This is a light weight, insulating castable with good resistance to flux. It has a much better thermal conductivity rating than Mizzou castable. I cast about 1" thick. I sell 6# bags for $15.00 each. I also recommend that this be cast over a 1" layer of Inswool, which I sell for $7.00 a running foot (2 foot wide). Then paint over the casting with Plistix which is an infrared reflecting product. Similar to ITC 100 but much cheaper. I sell the Plistix for $9.00 a pint. Plistix will make the forge heat up faster and heat metal faster. In a forge I built it cut heating to forging temperature in half therefore cutting propane use in half. After a full day of forging I can touch the outside of my forge. Building a forge this way keeps the heat and most infrared rays inside the forge where they are needed.
See my tutorial on the Tutorial Forum about building Gas Forges.
What do you think about using Mizzou over the inswool ? I have been using this to coat the entire inside. It is thick & chewy, but holds up well.
Mizzou is a "castable", but seems to go on fine if put on thick.
I do a layer in the bottom 1/4, let dry and then rotate, apply until entire inside is covered. This way the cement is always on the "bottom" no slump and I can get an even coat.
I lined my last gas forge with Mizzou over three layers of 1" 8lb ceramic fiber insulation. It has held up well even with a couple of experiments in forge welding that splattered borax all over the inside. It heats up quickly with one blown burner. The frame of the fire box is a large mailbox.
Doug Lester
Doug Lester
Gotta show us pictures my friend.
