I'm building my forge tomorrow! Kaowool outer layer, thin layer of 3000° furnace cement, and a layer of plistix once I order some from Wayne.
Quick question, where do I put my burner? It'll be 8" long, 4" diameter. Right in the middle of the 8" section, or more near the rear?
Also, does the enterence to the burner go parallel with the the top of the forge? I want to avoid a hot spot right under the burner if possible.
Using an atlas mini burner.
Thanks!
Thanks!
