Flat grind bevel angle?
I'm sure there are endless answers to this question, but in general, what would be a good bevel degree to be on a flat grind knife - intended for hunting/field dressing?
BrandonM
It will depend on material thickness, height, and whether you are doing a high flat vs. full flat grind. That said you will probably be in the 4-5 degree range. At least that's where my 3/16" thick high flat ground knives fall. Like this one.
@Brandon - I'm using 3/16 and that about the look I'm going for, so I think what you suggested will work as a good starting point. Thanks!
BrandonM
I forgot to mention I'm using 1.5" height material and the blade is probably 1.25" in height. Obviously 2" material would change the angle to something steeper.
I think I made my first of many errors and ordered a grinding jig that is too steep. The "pre-made" jigs offered were set at 25 deg angles, which seemed to lie-up with some of the things I was reading, but I'm now not sure if that is 25 total from one side to the other. The jig looks ridiculously steep, so I'm not sure I can even use it...
"The Montana Bladesmith"
My suggestion is to try a flat grind, with a convex edge. You can increase or decrease the degree of convex to fit the application of the blade, and in the process eliminate the "shoulders" on an edge that is sharpened at angles, which adds to the cutting resistance of a blade because of the "wedge" that's created when sharpening a blade with any type of fixed angle(s). The overall idea being to have minimal or no angled bevels on an edge..... the difference in cutting performance versus edges that are sharpened at angles is very noticeable, and in most cases very dramatic.
wall e
Hey Top, I second Eds suggestion. I learned the slow way of what position works best for me and my grinder. As far as degrees that doesn't come into play till sharpening for me.
I just ground a half a flat on a blade and learned how my hands an body worked at each point of the motion. I still have issues with over or under grinding my blade tips. Here is 3/4 of my full flat pre ht with 3 or 4 errors in it to fix still.
When you grind your flat you want one smooth surface. (If you already didn't know)
Ed and Walt,
Thanks for weighing in. I cut and profiled my first two blanks today. I can totally see what you mean about getting a feel for it and hand/knife positioning on the grinder and belts.
wall e
No problem, is what we all are here for, to help each other improve.
If you look at the pic of the grind I started there is 3 distinct lines where I changed my blade and belt meet angle.
