Grinder looks good. I do have a question, in looking thru
https://housemade.us/ website I'm not sure if all the welding is done on the grinder? OR, is it a bundle of pre-cut parts that you weld together? That is one long platen - How long is it?. There are times when I wish I had a longer platen myself.
It comes with all the metal parts/hardware, minus wheels. You assemble/weld the entire thing.
You additionaly need to buy wheels, motor, vfd, and wiring.
The metal platen face itself is 2x11", I haven't measured wheel to wheel tho, but seeing as they are 2" wheels I'd estimate 15-16" total.
The work rest table (not pictured) is very large as well, and angles up to 45°, and when you rotate the grinder horizontally you can orient the work table to the platen in that position as well, which is awesome.
I need to decide if I want to use my serrated contact wheel/arm and small wheel/arm and adapt them for this grinder, or buy a whole new set of tube steel arms.
Sent from my SM-G991U using Tapatalk
