Gliden07
Well I did my first grind on my Disc Grinder. Came ot ok I polished it up to 1K on the paper so I could see if there was any problems. Of course there was! Lots of radial scratches in the blade because I didn't spend enough time on a certain grit. Plus I used cheap HF paper, need to get some good Rhino-Wet and a spray bottle with water and a drop or 2 of dish soap. But beyond that the disc flattened the grind beautifully! Very happy with the way it works! Once I figure out the grit progression, get good paper and a little practice this thing will be a great addition to my little shop!
You cant see it in picture but there are a lot of scratches on the blade. Just need to work on it!!
