Elmax order of operations questions.
Kev
I’m starting a new project that will be using Elmax. Currently I am anticipating having the heat treat done by Peters. As for pre-heat treat work, what have those of you whom have worked with it before, how far did you go? Simple blank? Bevels ground in? Hand sanding? Fully polished?
Thanks in advance.
BossDog
Staff member
There will be some interesting opinions on this. Some guys grind only hardened blanks so they can address any warps. Some guys will take it 75% to 120 or 240 grit and then finish after hardening.
Some guys, like me, take blades nearly all the way and to a 400 or finer finish. If it warps, I make a new one if I can't grind out the warp. Most of the SS warps I have seen are from heat treat foil sucking up to the blade like a vacuum. I now sprinkle talc powder on every blade to avoid that. Peter's uses gas quench and neutral environment ovens so you don't have to worry about the foil part of it.
What I do know is Elmax is hard to finish when hardened. Hard.
Getting scratches out can be a bugger and over heating while getting those scratches out can be an issue. Grind a pass, dunk, repeat. Other super steels can also be tough to finish like S35Vn, CPM20Cv, M390 come to mind so those I take to final finish and then it's much easier to clean up any heat treat patina.
