I apologize for posting this, as I am almost certain it has probably been asked before. Unfortunately the term 'jig' is either too common or too short to search the forum for, and thus I'm forced to ask rather than simply search and learn.
What do your edge cutting jigs look like? Have most of you made your own, or are you all using the bubble jig? I've got a magnetic protractor with level on it, but it's not nearly as compact as the bubble jig.
My buddy on the other hand who is a 'retired' knife maker, only used a block of hardwood cut at an angle. I made a small jig using angle iron, and drilled a hole slightly bigger than a bolt going through the bottom. I then welded a nut to the hole, then threaded the bolt through the nut, which elevates and 'tips' the angle iron at a slight angle, and it worked pretty good as a semi-decent guide, but I'm not sold this is the best way.
I imagine the bubble jig is something I would highly benefit from in the future, however since I haven't made enough knives to sell yet etc, I am limited to either buying a jig or buying a forge, and working with pre-hardened steel is such a pain.
