I bought some of the chainring bolts to try on a knife for the first time. I ordered the ones that are 3/16" dia. with the .249 dia heads. What are you guys using to countersink the heads? I'm going to be using them on a G10 handle scales and the blade and scales are already drilled to 3/16". I'm going to have the blade Cerakoted, so I've got to get the handle scales flush before the blade is finished.
McMaster-Carr has some step drills but the small diameter is under 3/16". So my other option is to not use a step drill and eyeball the countersunk hole. What do you guys use?
