Adding to what's already been said... One of the big reasons that 15N20 is such a good "partner" for a damascus mix is the fact that it's essentially 1075 steel with the addition of 1.5% nickel. What this means is that its very much like forge welding two simple carbon steels. And as has been mentioned, the heat treating is very much as if the entire billet were a single carbon steel. Of course adjustments MIGHT need to be made in both the hardening and tempering to achieve the desired results.
For those who are newer to creating damascus, a very important aspect that must be considered is... what I call "compatibility" of the steels being combined. Every steel has specific expansion and contraction characteristics....meaning that they expand a given amount when heated, and contract a given amount when cooled. If a person arbitrarily combines two or more steels in a damascus billet, without considering the expansion/contraction properties of each individual steel, it can easily become a train wreck. If one steel expands or contracts more then the other, on the mild end it causes warpage. In severe instances, a damascus billet can literally tear itself apart....usually during the hardening/quenching operation, which is easily the most "violent" thing that steel goes through during the knifemaking process.
Personally I choose to use 1080/1084 and 15N20 for the majority of my damascus making. With the exception of the 1.5% nickel in 15N20, the two steels are nearly identical, both in make up, and in their expansion/contraction properties. I look at from the standpoint of not having to make things any harder for myself then necessary, within the realm of achieving my desired end goals. Forging these two steels creates very solid, trouble free billets, and allows me to do more complex manipulations then would be possible with mixes of steel that are less "compatible".
