Hi all,
I've been watching some videos of knifemaker "Gavko" videos on Youtube. He's a knifemaker that seems to have tested a lot of blades.
He's adamant that a convex bevel is the best grind. I've read the arguments for a convex edge (and I'm not asking to open a debate on edge geometry), but I haven't heard nearly as much talk about convexing the bevels.
If you are curious, here's the video I watched. After establishing his flat bevel with a 50 grit belt, he glues a thick piece of felt to his platen to convex the bevel with a 50 grit then 120 grit. Then it is heat treated. I'm sure he didn't invent the technique, but I've not seen anyone else doing it.
http://www.youtube.com/watch?v=FY1vpF0ZgMA
So...
Is it 'better'? If so, in what way? Stronger or cuts better? Any reason why more people aren't doing this? I have seen videos of people using the KMG rotary platen for convex grinds., but it doesn't seem to be nearly as popular as flat or hollow grinds.
I would think it's not as aesthetically pleasing due to the lack of crisp grind lines. Seems like it would have to be a full grind up the the spine or blended into the flats. (But I haven't seen a good picture of Gavko's finished knife with a convex bevel.)
Thanks.
So...
Thanks.
