John Wilson
Those are black oxide allen head bolts.....likely with an internally threaded sleeve...... not something you would see an experienced maker use.
That answers my question. Don’t do that! haha!
Is a pathological need to clamp a bad thing?You don’t need to any extra clamps when gluing with Corbys but there is a pathological need to clamp also. It won’t hurt unless you squeeze all the epoxy out. I don’t use clamps with Corbys.
OH Goodness YES! I think you should talk to your Doctor. I'm sure there is a drug out there for that!!! Although I suspect the side effects would be like...... you eyeballs will fall out, you'll get athlete's foot, and your teeth will turn purple!Is a pathological need to clamp a bad thing?
Oh!! I better run home at lunch and take the clamps off handle scales I glued up last night!!OH Goodness YES! I think you should talk to your Doctor. I'm sure there is a drug out there for that!!! Although I suspect the side effects would be like...... you eyeballs will fall out, you'll get athlete's foot, and your teeth will turn purple!
Disclaimer: OK....just to be sure....that is ALL sarcastic!! DO NOT try this at home!
