Kevin R. Cashen
Super Moderator
My test block is from Westport. Theirs is maybe $82 I think? They tell you +/- 5 points when you order it. Then it is etched on the side of the block with the actual hardness and a range of +/- 0.5 points. They do send you a certification sheet with all their readings on it.
I see you have one of the HR 150 units, good call on getting a better block, the Chinese ones that come with it are pretty rough affairs. I used one of these testers for around 10 years, solid unit so long as you check it. Once it went out and the pattern scattered it was done. But, to be fair, I did use it to death.
