Can't find the right drill bit.
1095 is notorious for having hard spots. We stopped using band saws on 1095 years ago after losing too many blades to hard spots. You can anneal a hard spot a couple different ways.
1. Anneal the whole bar using a forge or oven. 2. Spot heat with a torch to cherry red and let it cool slowly 3. Put a metal dowel pin (or upside drill bit) and with the drill on the fastest setting run the flat against the spot with lots of pressure until it heats up to a dark cherry red. This method is fairly quick and will at least soften the hard spot you need to drill.
that is genius
