SS369
I roughen the to be bonded surfaces (including pins) with 60-80 grit, clean and clean again everything with appropriate solvent and let dry.
Then I assemble it all, coating all surfaces liberally, fill the through holes and generally use three spring clamps. Using warmed Gflex 650 I get squeeze out all around and that tells me I have sufficient adhesive. The spring clamps provide enough pressure unless something is wrong.
If during a mock up run all looks just right, then it should be good to go with epoxy.
SS
SS
