SWAG , huh?Yep, I look at the steel I am forging, and sort of imagine it all squished into the shape of whatever I’m making, and use that much of it. Very scientific.
What’s “SWAG”?SWAG , huh?
Ah, I get it! Yep, that’s my methodI believe he's referring to the scientific wild ass guess...
yeppers, yall unnerstan hillbillyAh, I get it! Yep, that’s my method
Every knife I've forged, I didn't measure anything. I figure out the lengths I need to forge and write down the rough numbers. As I forge, I'll mark distances on my anvil face with soapstone.One of the first knifemaking DVD's that I bought was the Charles Ochs basic forging video where he made a 7 inch fighter from 52100. He took a 7 inch piece of 1/4 thick bar stock and forged the though tang knife from it. Combination fo thinning a little bit and distal taper made it work.
Now that’s what I’m talkin about! I knew all that math I took would come in handy. I’ll have to go back and read up because I don’t remember studying the swish factor, must of missed that day. Thank you, sir. Heading to the forge to squish some shit out!! LolYep, I look at the steel I am forging, and sort of imagine it all squished into the shape of whatever I’m making, and use that much of it. Very scientific.
ThanksI don't forge a whole lot, but enough to have a plan when I do. I forge 1/4" stock mostly. I figure it it terms of finished dimensions, plus material loss. So if I want an 1/8" thick knife, 1" wide and 10" long,
I'd start with 1/4" thick, 3/4" wide, 6" long, and grind off extra thickness or cut off excess length as needed.
ThanksEvery knife I've forged, I didn't measure anything. I figure out the lengths I need to forge and write down the rough numbers. As I forge, I'll mark distances on my anvil face with soapstone.
I forge the blade first on the end of the stock, then start to draw out the tang a little, estimate how much metal I need for the tang, and hot cut my stock off there. Then I forge the tang.
I work almost exclusively from round bar stock. 1/2" being the smallest I think I've made a knife from. Usually 3/4" to 1" bar. Just cause it's what I have on hand. I got a bunch of it a while back (and might be getting more, soon).
ThanksI'd you're copying a knife...
If you want to get fancy, you can drop the knife in a graduated cylinder, fill it up with water, pull the knife out and measure the change.
Or put the knife on a scale and do the math. Mass to volume.
OR draw it in CAD and extrude it to thickness and look at the material properties - namely volume.
