Maybe the single best reference article on knife steel selection ever.
Larrin is on Patreon.com as www.Knifesteelnerds.com
We encourage you to browse his posts there and if you find value in the, support his efforts via Patreon.
Knife Steels Rated by a Metallurgist - Toughness, Edge Retention, and Corrosion Resistance - Knife Steel Nerds
Steel Metallurgist Larrin Thomas uses tests of knife steels to rate the steels and explains the factors that control performance.
knifesteelnerds.com
