scott.livesey
Dealer - Purveyor
good to hear. i think if you found some steel square tube and made a place for your blade to sit, you may have better heat control inside your forge.
Per Chuck of Alpha their steel is spec'd to be in a state ready for HT and should NOT need any steps before HT. From AKS website:I've read this as well as I've been trying to determine if I need to normalize Alpha 1084. I didn't and it worked out fine...
Why would you quench at 190°? Your quenchant should not go above 140° unless you are working towards marquenchingThanks, I do have an RC Tester. I just completed one knife this afternoon and it tested 62HRC.
I brought my forge up to 1490 and stabilized it pretty well. I do have a high temp sensor in the forge, but it does fluctuate a bit and some parts of the forge look hotter than others. I make sure to move the blade around inside the forge to try and keep uniform heat and color in the steel.
I did the heat treat in the garage so I could judge the color of the steel.
I quenched in 190 degree canola oil. Cleaned the oil off and put it in my regular oven at 400 for 1:30 minutes. Then I plate cooled it in aluminum plates for 10 minutes.
I'll try and work on some coupons tomorrow and try a few different things.
