Advice regarding HT oven build
ChrisBo
New Member
Hi, new member here, I'm Chris from Malta. I'm in the process of building an electric heat treat oven, but before proceeding further I would like to get some advice. So far I have built the oven chamber. I could not find any insulating fire brick local to me and importing from abroad would be prohibitive, so I'm trying aerated concrete brick from Ytong. I have experimented for a while with this material and it seems to be able to handle the heat. It's thermal conductivity coefficient is 0.15W/mK which is close to K23 brick so I'm taking the risk. The internal dimensions for the oven are 40*20*15cm.
Next up are the heating elements, my mains supply is 230v 13amp so I could go to 3Kw but I'd rather limit the current to 10A, that would give me 2.3Kw. I have 20m of 1.2mm Kanthal A1 wire which I bought a couple of years back (yes this project as been on the back burner for quite a while!)
My plan is to use this wire for the element, but before jumping in I would like to hear some opinions and advice. I have read through the forum, online and youtube tutorials and although there's a lot of information sometimes it gets confusing!
Regards
Chris
