Brian West
Member
I did some research and followed the heat treating advice of Kevin....mostly. Where I strayed was with the quenching medium. I understand 1095 requires a fast quenchant like brine or Parks 50. I only have medium oil (canola) so that is what I used. Based on my qualitative observations after quenched it was not quite as hard as it could have been. No surprise right.
So my question is, what HRC should I expect having used the following heat treating recipe with the medium oil.
Stress Relieving at 1200F for 10min
Hardening at 1475F for 10min
Quenched in 5gal of canola at 130F for 7seconds moving up and down (200F when pulled out). Maybe 1sec between oven and oil.
Knocked off scale
Tempered in oven at 400F twice at 2hrs, water quenched after each
Med. straw color when finished, no warps
Had I used the appropriate quenchant, I would have expected 66 HRC as quenched and 62-63 after tempering. Do I have a useable blade? It sure took a sharp edge. Thoughts? Going forward, I will use brine and take the chance or just change steel.
Thanks!
Knocked off scale
Thanks!
