thanks never had a problem beforeIf you're sure that your forging temps are close, based on your description I'd expect large grain to be your main issue. Since you're getting cracking you might as well see what that grain looks like. Two or three heats in the 1475F range after your 1600F normalizing heat will make a much finer grain. I don't think one 1600F after forging temps will get it lined out.
