CDHumiston
I use a vise with aluminum plates, and clamp the blade in, still in foil if I’m using it. I don’t use a lot of pressure, probably about 50 lbs, and they come out nice. One thing that you need to do is make sure you use foil or a purge. I run nitrogen purge gas in mine, so I rarely use foil anymore. The high temps and long soaks that stainless needs will really scale up bad if you don’t.
I had a brain fart once and put a couple of 440C blades in the kiln with no foil. You are not kidding about scale. Basically ruined the blades for anything but personal use and a hard lesson...
