KentuckyFisherman
I've read some posts where advice is given about how to keep scale pins from overheating, but I swear I can't find them. If you KD veterans know of threads dealing with this, just point me that way, and I thank you.
If, like me, you can't find existing advice, here's my question:
I have no trouble with brass pins getting too hot when I cut them off or grind them down as I finish shaping my scales. But on my current build I wanted silver pins, so I used some 1/8" stainless steel pins. Man, those suckers got blazing hot when I cut them with a Dremel and also when I ground them flush on my belt sander. I kept a wet rag handy and cooled the pins often, but that much heat couldn't have done any good to the epoxy.
Would it help if I switched to something like nickel silver? If stainless is OK, how do you keep them cool when cutting and grinding? Thanks for any tips.
