I'm bringing along a group of knifemakers who are relatively inexperienced. One of them brought me a batch of knives to rockwell test last night. One of them tested around 59, but the others were all still soft. The steel was 1095.
The reported heat treat was to heat it to "nonmagnetic" in a charcoal forge, then quench in warm/hot motor oil. All of the blades had some of the bubbly look that I typically think of as signs of over-heating. Just for kicks, I also ground one down a bit to ensure I wasn't just testing surface de-carb.
My theory is that the HT failed because he overheated the steel, then used too slow a quench. If I understand right, that leaves grain growth and mixed pearlite, both of which contribute to a soft blade.
If I'm right, and the steel is currently mixed structures with large grain, what needs to be done to get things back to good? I assume the steel is enough of an unknown mess so that another heat/quench alone won't do much good.
I pointed him toward less heat and a faster quench, but what else? Normalize in descending heats? Sub-critical anneal? He doesn't have the temp control to do these steps well, but I could let him use my oven.
How do I best help this guy? I offered him a couple feet of 1084 already.
