TW90 Set Up
opaul
Just finished setting up the TW90 and rearranging the shop. Still stuff to do but I'm going to take my time, I have a tendency to burn myself out rather quickly. Can't wait to try it out! Profiling the Bowie might be the first blade steel on this one. Put the KMG on the market this morning!
Looks great. Would be interested to hear a little feedback on your thoughts once you have used it a little while.
If you think about the square edge of the tool rest against the flat surface of the platten - if you want to adjust your tool rest down (say 45*) the bottom edge of the tool rest is going to come into contact with the platten. But if the bottom edge of the tool rest is beveled - when you rotate it down you have a nice close intersection of the tool rest and the flat patten surface. Or say with a KMG - rotate the platten back away from you to create the angle.
I hope this makes sense.
Makes perfect sense... thanks OP!
