cardoso5fr
What you neet
Material
steel for blade
stainless steel plate
2 pivots
4 screw(M3)
2 tang .
4 washer
Tool
To fold a vise, hammer, blade+washer thickness steel place,
To cut hack saw, band saw, angle grinder
To grind file, sandpaper, angle grinder, belt sander, backstand.
To heat treat Blow torch, torch, forge, heat treatment oven, oil or water
To fold the steel, you put the plate in the vise to the folded highness you want. You put the two plier wrench , you fold to more than 90°, after you press the plate in the vise. You use the hammer (on an anvil or something strong) on the U you obtain in order to straighten it with the thickness plate in the u
After the folding
To the angle grinder i cut the place where the blade will go. more or less 2 cm deep.
Steel plate, ink, some draw....
After some bandsaw work.
It's shaped.
i clean the part i cut with the angle grinder.
I draw the middle of the blade
The scale are in position
I point the futurs holes.
3.8mm
I reamed to 4mm the pivot, the tang place stayed to 3.8mm
Drilled and reamed
I point the futurs holes in the handle.
3,8mm
Reamed to 4mm
I build it in order to see where i have to not grind around the pivo
Draw of the futur handle.
I cut with the bandwaw.
It begin to seem to be a balisong
Open
I shaped a bit with a 60 grit belt.
I did the choild with dremel rotary burr.
Cleaned everything with 240 belt
My grind plied, (simply O1 hardened pieces with a stainless piece and two rolled pins.)
60grit
120 grit
It's thin before HT
Lazy fileworked
Propan torch oil hardening
Hardened and degreased. (to not too much dirt my belt)
The grind is white in order to see the color during the flash tempering
Flash tempering, the point is a bit darker, but it was 4mm too long, the point had been decreased after to go in the handle
. And i temperered generally a bit more the point of the balisong.)
240 grit
500 grit
My poor stencil.
Electro etching
I decreased a bit the diameter of the tang in 100c6 hardened.
Everythin is on the spot, at the right size and polished.
Tang cup with the rotary burr.
Open
I cut the screw and polished the cut.
The pivot are decreased to the right size.
Polishing.
15 parts
500 grit to create the edge, some buffer to complete the work.
You have a small balisong not too much "bling bling". the aim is to use the same idea of the folded handle that i use to my Cardo No Kami.
It's thin, and cool to flip even if it's a bit short and thin to offer all the possibilty of a full size balisong.
9cm closed, , 3,2 cm widht, 7mm and 1cm to the thickest, open 15,3 cm, 6 cm sharp. XC75 blade full hardened, gold flash tempered. Hardened tang pins. 74g.
Material
steel for blade
2 pivots
4 screw(M3)
2 tang .
4 washer
Tool
After the folding
It's shaped.
3.8mm
Drilled and reamed
3,8mm
Reamed to 4mm
Open
60grit
120 grit
It's thin before HT
Lazy fileworked
240 grit
500 grit
My poor stencil.
Electro etching
Open
Polishing.
15 parts
