"The Montana Bladesmith"
Steve Kelly (TiConnector.com) and I are best friends...we talk each Monday morning, and during our last conversation, something came to my mind.....Steve was telling me how some folks buy his hardware, then try to modify it to do what they want. (which sometimes goes badly) It occurred to me that many MIGHT be going about things the "hard way" when it comes to designing and building their folders.
First, don't try to design a folder, and then try to modify the hardware to meet the needs of the design. Get your hardware first, and design the folder around the hardware. By that I mean that you can still design whatever you want, but if you're buying .190" standoffs, don't try to shorten the standoffs, but rather make your blade the correct thickness...which is much simpler and easier then shortening standoffs.
With pivots, think about the entire length your project will need, and if available order those. (think about any counterbore depths, such as bearing pockets and/or pivot screws.) If you do have to shorten/trim pivots, remember that you MUST shorten them equally from each end.
With folders its really all about the math..... if your standoffs or backspacer is .190", and you're using .010" thick washers, then your finished blade should be .170" (.190 - .020(for the washers)=.170") Should you be using bearings, taking the time and care to make sure the bearing counterbores are as close to perfect in depth and square as humanly possible. (persoanlly I counterbore .050" for 1/16" (.0625) wich leaves .012 above the counterbore, which generally seat in approx .002, leaving .010 when everything is "broke in".
Without going on an on, your life making folders is MUCH nicer when you build to the hardware instead of trying to modify the hardware.
Just something thats been on my mind, and hopefully will help somebody.
