BladedBonehead
I got some of this ..enough to make all 13 ti blades. This is the 'mirage' which is a transparent kydex like material that so far is very interesting. It works like Concealex or good Kydex and comes covered with a film on both sides as I am sure scratches bite when you can see through the holster or sheath, even in the overlap areas. I will be seeing next how the material holds up for normal use and with dirt. It is slightly more expensive than Concealex or Kydex and there are more colors. The same skills needed to make a Kydex sheath are the same except for the fact the chips and dirt need to be kept out of the inside of the sheath.
By goatherder62 at 2012-08-31
